How it works
- Switch on with the toggle button
- After esp32 boots up, it automatically connects to my home WiFi
- Then it loads a pre-configured REST service - hosted by me - that returns a number: how many seconds do I have until the next tram arrives.
- Device converts it to minutes and displays it on 2x7 segment display
- Device continues polling the REST endpoint in every 10 seconds and refreshes the 2x7 segment display
Device Setup
Ingredients:
- 15 x 110 Ohm resistors
- Toggle button (ON - OFF)
- ESP 32 module
- 2x7 segment display: i am using DA08-11EWA
Configuration
In order to make this work for you, you will need to
- Host a REST service that connects to your local commuting service (in my example it's "BKK futar" in Budapest) and responds a number: how many seconds left until bus/tram/train/etc arrives. Once you have this REST service deployed, make sure you updated esp32/main/main.c WEB_SERVER, WEB_PORT and WEB_URL parameters.
- Configure ESP 32 WiFi under esp32/main/main.c EXAMPLE_WIFI_SSID and EXAMPLE_WIFI_PASS - yes, this comes from an esp32-idf example :)
Sources that you have to deploy to esp32:
https://github.com/akos-sereg/esp32-commuting
Akos Sereg
rishab
Martin Fasani
