All parts of the project can be found by clicking here:
This is the sub-project for Automated Living: This is the server backend component
apt-get install xinetd tftpd tftp
and in /etc/network/interfaces :
auto enp3s0:1
iface enp3s0:1 inet static
name TFTP Server
address 172.16.0.251
netmask 255.255.255.0
broadcast 172.16.0.255
network 172.16.0.0
and then
/etc/init.d/networking restart
ifconfig
enp3s0 Link encap:Ethernet HWaddr d4:3d:7e:ba:a9:56
inet addr:10.0.1.74 Bcast:10.0.1.255 Mask:255.255.255.0
inet6 addr: fe80::d63d:7eff:feba:a956/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:433088 errors:0 dropped:0 overruns:0 frame:0
TX packets:11424 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:66214575 (66.2 MB) TX bytes:1114489 (1.1 MB)
Interrupt:19
enp3s0:1 Link encap:Ethernet HWaddr d4:3d:7e:ba:a9:56
inet addr:172.16.0.251 Bcast:172.16.0.255 Mask:255.255.255.0
Interrupt:19
Sweet, up and running!
next I will configure the services!
I just recently got my office in a (mostly) usable state at the new house, and threw my hand usb installer into the PC I was going to use as a server with a fresh 3tb sata drive, I came back to it today and found things were a hot steaming mess, the scripts I have on my auto installer relies heavily on having an internet connection, this was actually the first time I have had a problem with this, I should make everything fail gracefully, it doesn't, it turns it into a hot mess.
Right away I found the problem, the integrated NIC is putting on a good show, but its all for show.
It gets a link light, you can detect the interface, but it wont DHCP, and wont respond to static settings, I booted a LiveUSB to confirm it wasnt just an issue with this install, no dice.
Maybe now I remember why this PC landed in the reuse pile.....
I know somewhere in this house exists a PCI-E NIC, I just saw it...... a few weeks ago?
Oh boy..
Today I will be working on getting the first server set up, I will post its specs here as soon as I figure out what machine I will use...
Its roles will be:
TFTP Server (boot SBCs)
Central Log server
Notification server (using prowl to send messages to the phones)
Video Transcoding (lowest priority)
HDMI framegrabber (more details soon)
It will have a virtual interface sitting at 172.16.0.251 for TFTP serving so I can hard encode the address in uboot and let this be as easy to deploy as possible without interfering with standard network setups.
The base will be Ubuntu 16 Server
