ok this is a quick update, I have fixed up the GUI a little, decided to set it to take the look and feel of whatever os it is currently running on. I have also tidied up the code a little too, I hope to release the first version to the public before the week is up, I'll probably just release it as a zip folder containing an executable jar file and the netbeans project folder, I've never used git hub before so I'll considering looking into how to use it (obviously a newb here). anyways here a pic with the native windows 8.1 look and feel.
I will try and test this on a spare laptop soon and see how it works with alternative keyboards (still looking for a better solution than the java robot class), I will also try and start testing inside linux and see how it looks and works.
