So, in anticipation of needing all of the pins and pads on the Teensy to accomplish my dark work, I have revisited my Teensy pin expander project "Megsy", adding support for an external USB socket, and better placement for the bottom pads, and better routing so that it might be made on an OtherMill PCB router.
Full project log is in the Megsy project here.
Tina Belmont
