Autodesk Fusion 360: The Honeymoon is Over
A project log for NanoEgg Music Synthesizer
A powerful little music synthesizer with a classic look!
tina-belmontTina Belmont 08/12/2016 at 21:340 Comments
Evidently I am now an unpaid, unofficial tester for Autodesk. Wasn't my intention. I just needed to use some CAD software. But nothing ever works perfectly... here are links to the various bugs filed, features requested, and questions asked I have posted since I embarked on using the Fusion 360 software.
"Offset" does not retain Parameter reference
"Sketch Geometry is Overconstrained"! Won't add new constraints...
Screencast Interface too small for 4k Monitor
Can't snap to entities in other sketches
Select multiple, non-contiguous entities for "offset" and similar commands
Remember last settings for commands like "Offset"
List / sort constaints
Editing dialog for all elements, from sketch up
Sketch elements in hierarchy treeview
Block rubberstamp for repeated elements in sketches (like Solidworks)
How do I group sketch elements?
