I mentioned in a Previous post that before we can start manufacture, we need to have some basic functionality tests to preform QA testing. For a couple of months I was unable to work on this project, but now I am back to being able to spend most of my weekends again. So I have been able to make some progress.
Currently the following is ready:
- Testing rig with a motor and encoder
- Testing PCB with pogo pins to make quick connections during testing
- Low level code to trigger current sensing and motor control from the 3-phase PWM pheriperal
- Online current sensor calibration
- Lock-in, open-loop voltage vector motor spinning
- Automatic motor resistance measurement
The following is still left to be done before manufacturing can commence:
- Test that the bed-of-nails board makes good electrical contact
- Check that the transient response of the current sensing is good
- Low level code to allow hand-over of the ADCs between the two motor channels
- Write the encoder drivers
- Finish up the test routines to be able to detect faults
Pictures and video!
Below is a motor-encoder pair doing lock-in, open-loop voltage vector motor spinning.
New motor test cradle. The design is openly available, Link.
Some pictures of the bed-of-nails. The design is openly available, Link.
Hmmmmm, sexy bed of nails, I hope it works out.
