Capabilities and Demos
Overview
"The general design is presented using layers. The bottom layer supports the physical components that compose the robot, such as motors, IR sensors, expansion sockets and modules, RGB LED, LiPo battery, LiPo charger, and a global positioning system that uses an overhead camera. The peripheral layer is powered by the ATmega168A microcontroller, which manages and drives all the physical components. Above that, the control layer performs the necessary actions to safely drive the robot in its environment and complete tasks. The application layer describes the individual and collective actions that emerge when the robot or group of robots are operating. Finally, the top layer allows the user, through the communication layer, to debug, run, start/stop, and program the robots.
Hardware Description
The complete hardware is shown in the previous picture and is composed of robots, a computer, a web-cam, and a controller board (the green one attached to the computer). The user can write codes to program the robots using AVR-Studio on the computer. Additionally, the computer runs the 'Central controller' software, which enables the sending of commands to the robots and the processing of web-cam information for global positioning. The 'Central controller' software is compatible with any web-cam with a minimum resolution of 340x480 and 30 fps. The computer application communicates with a Central Controller board via USB to send user commands to the robots wirelessly. The 'Central controller board' has an AT90USB162 microcontroller that receives USB data from the computer and sends it to the robots using the NRF24L01 module. It also allows for wire programming via AVR-ISP
Robot Main Board
- Locomotion subsystem: It is based only on the contact between the rotor of two tiny 3V electric motor and the surface. The manage of the motors speed and direction is done by the microcontroller, using PWM and digital pins, using the TB6552 driver .
- Communication: Here, we use an ultra low cost transceiver RF (at 2.4GHz) module NRF24L01, which gives the robot the possibility to interchange data with the operator and other robots.
- Power and Charging Management: The electronics are powered by a 3.7V, 200mAh LiPo battery. A voltage regulator is used to maintain a constant voltage of 3.3V and enable operation above 5 hours of constant working. Also an external LiPo charger has been built that uses an MCP73833 to manage battery reload.
- Assembly and Costs: Three custom 3D print parts for easy setting-up and calibration of the motors and IR sensors are designed. These two pieces do not need to use glue or screws. An exploded view of mechanical assembly is shown. The 3D pieces models are available Here.
- The Electronic design is available Here.
Lipo Charger
The Lipo charger board is USB (5V) compatible, it allows to charge a single cell Lipo battery, using the IC MCP73833. It recommendable to use a GP connector between battery and board (take care about polarity !!). The design and fabrication files are available Here
Central Controller Board
The Central controller board is also USB (5V) compatible. It has two functions:
- First one: It can be used as a programmer emulating the AVRISPmkII programmer. Refer to the software section to it usage. When you have configured the Central controlled board as a AVIPSmkII programmer you just have to interconnect the ISP pins of this board and the ISP robot socket and avr studio to code and run your code.
- Second...
AndresRengifo
Ben Lim
Roald Lemmens
Lidor Shimoni
Hi Andres, coooool!!!!
I'm impressed with the similarities of a project I'm just working on. You can see it here: http://letsmakerobots.com/node/47585
If you like, we can exchange informartion/ideas/comments as I'm doing more or less the same as you.
Congrats!!!!
