USB Type-C/USB PD Analyzer
USB Type-C/PD Analyzer is an Open Source Hardware/Software tool that helps you test, debug and explore USB Type-C/PD Devices.
Tool captures, analyzes and decodes USB Type-C/PD data over the new USB Type-C Configuration Channel (CC) and VBus in real time. The captured data is dFunctional Specifications
· Open Source
· Spec support: USB PD 2.0 and USB Type-C 1.1
· Allows pass through of legacy USB, USB 2.0, USB 3.1, and Alternate mode
communications
· Non-intrusive, preserves signal integrity and timing conditions
· Transparent interposing on a USB Type-C connection
· Displays Packet timing
· Monitors USB Type-C state machine
· Exporting received packets as CSV and proprietary bin file format
· Complete PD packet decoding
· Supports Real time decoding and Error detection.
· Sniffing PD traffic on both CC lines
· Displays the CC packets in a human readable form
· Monitors CC and VBus line voltage and displays in graph f
Rich text editor
devorah wrote 03/31/2022 at 19:31 point
same question
Marius wrote 07/18/2018 at 07:58 point
any progress, releasing all sources?
