Started to assemble and apparently I should've waited for my amazon order of the worm gear to come in so I could measure it...doesn't quite fit. Not a large problem. Should take about an hour to redesign the yaw motor mount and another hour to print it. Should be fixed by the weekend.
Also having trouble replacing the rod in the stepper motor. Man those pieces are on snug. Need to figure out a better way to get them off.
