Open-source model and RGB LED Development Board.
The part sheets for the rocket and launchpad model are laser-cut from premium unfinished multi-ply cross-woven Carbonized Bamboo sheets. Besides the standard build with the RGB LED Development Board, there are 3 optional builds (non-illuminated model, CCFL Lamp, & Table Lamp Base)
The RGB LED Development Board has a purpose and has some base functionality to build upon. Right out of the box it can be used as an accent or night light that is capable of reproducing over 3000 unique colors (firmware upgradeable to over 16M colors). It has been designed to be upgraded, augmented, and other wise hacked to suit your needs, wants, or desires. It's use is not limited to just the illumination of the rocket & launchpad kit, you could easily use the board to illuminate your own design.
Arnov Sharma
Steve Smith
supertech
Jerry Isdale
