The UI has now been structured and in large parts rewritten to be easier to follow and to continue developing. I also changed the logics a bit and the added "Synchronization Manager" will help keeping track of your parameters.
There are still a few bugs, e.g. the calibration table cannot handle symbols being uint32...
Next up is to add a data recorder so that you can analyze the measured data elsewhere.
