Wake up! It's Saturday. No time to sleep in. Lots to do. Drag yourself downstairs. Put on the kettle. Dig through the scrap wood pile and find something vaguely the right size. Oversteep the tea because you're not paying any attention to it; it's too early in the morning. Find the parts. Lay them out.
This looks vaguely right. Three bottles on the upper right for developer, fixer, and clearing baths. One outlet on the right for waste. Two pumps on the left that head up to the one developing tank. And builders' tea to give me that necessary construction boost.
I think maybe it should look something like this...
yeah, that. But with three bottles. This could work. The caffeine's starting to do its job and I'm thinking it might not be too early in the morning to fire up the table saw and lop off part of that plank. Maybe I'll have breakfast first though.
Breakfast passes; the plank is sawn; and now what do I want to do about the developing tank? I've had in mind that I could drill a hole in the bottom of a Patterson tank, add some sort of leakproof valve attachment, and probably not compromise the dark of the tank. Not too much, at least. We'll see.
The hole is easy to drill: pilot hole, check. Spade bit easily does its job without fracturing the tank. Phew. Attachment fits, and after some initial testing, I realize it needs adjustment. I went with the pair of
Colder PLCD16006 Acetal Tube Fitting, Coupler, Shutoff, Panel Mount, 1/4" Flow Coupler x 3/8" Barb
Colder PLC42006 Acetal Tube Fitting, Insert, Straight Thru, Panel Mount, 1/4" Insert x 3/8"Barb
Thogus Nylon Tube & Hose Fitting, Adapter, White, 3/4" Barbed x 3/8" GHT Female (Pack of 10)
Jorj Bauer
