All Components Attached
A project log for Guided Rocket
I will be attempting to build a guided rocket using of the shelf parts
sagarSagar • 06/20/2014 at 20:50•0 Comments
As each piece of the electronics were tested individually, it was finally time to mount everything in the electronics bay. The IMU was mounted in the front so that it picks up even the smallest changes in rocket orientation. The rocket electronics went from this:
To This:
