After adding a couple last features to the simulator (manual packet creation, node on/off, etc.) I have decided that it is done (for now) and that I need to move on to hardware implementation. I'm working though the RF24Mesh, RF24Ethernet, RF24Gateway, RF24Network, and RF24 Arduino libraries. They're really complicated. They total several thousand lines of C++. The RF24Mesh (and maybe the Ethernet one) were done by TMRh20. He has done a lot of hard work, and you should check it out.
The Plan:
- Get the examples going from RF24Mesh and RF24Gateway libraries
- Ping nodes by IP via Raspberry Pi
- Quick side note: The Raspberry Pi is connected to its own NRF24L01 module and it can act as a gateway to connect the mesh network together with IP addresses and also route them out to the LAN. Pretty cool.
- Ping the nodes by IP via something else on the LAN
- Start to dig into the RF24Network library and replace the network mapping algorithm with my own
- That should pretty much take the rest of my life...I'd better not add a 5th step...
And you thought I didn't have a plan!
