I purchased a 450x400x3mm aluminium sheet off ebay for this bit, i cut the main shape out on a bandsaw and sanded the cut marks out.
I have already drilled and countersunk the screws in the bottom for all the extrusions and the components that will sit inside. I want this machine to be as clean as possible, i.e. no PSU strapped to the side :)
