Mounted some of the electronics into the base of the printer, there is not much room for that PSU but it does fit.
Need to source some tie wrap bases to route all the wiring nice and neatly, using this layout I should be able to keep all the mains wiring far away from the stepper wires and limit switches.
Aaron Dominic Richmond
