I hate to write this down, but I will do it anyway: The system is dead, and I am not going to replace any plants anymore. I will try to pot the last couple of plants if they survive the day, and then I am going to shut this project down. When your plant roots start to smell like a swamp, you know it will go down pretty quickly. And if slimer started to invest the pump and clogging up the internals, you know its game-over. So, I decided not to continue this project anymore and consider it a total bust. I might reboot this project when i have a new house, my girlfriend supported me on this idea, so not all hope is lost, however I will do it with a better setup and a better understanding of my failures.
Couple of things for those that want to follow in my footstaps, here are some things that I have been running into and the fixes I have done:
- Ultrasonic misters will heat everything up to a nice 45C, killing all plantlife.
- NPK in an aeroponics system can kill plants pretty quickly
- Be aware that caterpillars will infest your system and eat everything before you had the chance to spot them.
- Keep everything clean. I constantly faced brown goo in my pipes clogging everything up
- Get yourself a decent cooling and water pump, preferrably one with a filter in front.
- Slimer will always lurk in the dark corners, waiting for you to not pay attention and then strike
- Make sure you can carry the water, or have a drainage pipe.
- Be prepared for water leaks. They WILL happen!
- "flexible" pipes are not that flexible as it seems when they are constantly under water.
- Have a backup plan. You will face the problem that stuff starts dying.
- If you cannot keep plants alive for more than 2 weeks, then you are doing something wrong.
- Get someone with experience on board first, before trying something that does not work.
Feel free to comment, discuss and give me ideas for a new project (either aquaponics, vertical garden or aeroponics using a water mist, anything that does not need ultrasonic foggers). I am absolutely sure that the next project will be in a new house, with a new garden and most likely will have a greenhouse so I can try out new things. So, if you happen to stumble on my project, please DO read all my logs, they contain a great source of information and can be really helpful if you want to pursue my dreams...
Julius (Mr. Seeker)
It very well could have been the water you were using you need to use reverse osmosis water withh added nutrients an k33p an eye on your ph levels
