--FIRST UPDATE--
So after a bit of experimentation I finally came up with an unoptimized code to display the factors of 10 of the minutes.
Like I said, this is just for me to be sure everything will work like I imagined.
I took a picture of the testing-setup while it was displaying 23:3xh.
Today I will continue to get the second part of the minutes section to work.
Her you have my unoptimized code. Let's see what I can do to make it a bit shorter in the final product:
#!/usr/bin/python
# -*- coding: utf-8 -*-
# modules
import RPi.GPIO as GPIO
from time import strftime, sleep
# setup GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(5, GPIO.OUT)
GPIO.setup(6, GPIO.OUT)
GPIO.setup(13, GPIO.OUT)
GPIO.setup(19, GPIO.OUT)
GPIO.setup(26, GPIO.OUT)
# functions
def displayTime():
minutes = strftime("%M")
row_3 = int(minutes)/10
row_4 = int(minutes)%10
if row_3 == 5:
GPIO.output(5, True)
GPIO.output(6, False)
GPIO.output(13, False)
GPIO.output(19, False)
GPIO.output(26, False)
elif row_3 == 4:
GPIO.output(5, False)
GPIO.output(6, True)
GPIO.output(13, True)
GPIO.output(19, True)
GPIO.output(26, True)
elif row_3 == 3:
elif row_3 == 2:
elif row_3 == 1:
else:
# main program
def main():
try:
while True:
sleep(0.1)
displayTime()
except KeyboardInterrupt:
GPIO.cleanup()
if __name__ == "__main__":
main()
I hope you have fun following the project! See you soon.
You could use a table/array, or a more compact coding technique :-)
