This 12V power supply is based on the LT1302. It should be capable to power some Portable Stereo Speakers we are working on. With a theoretical 120mA output, it can power many things else.
Here is an idea for using two AA batteries to get a 12V power supply.
004-enceinte-alim12V_rev2.pngCircuit diagram of the power supply.Portable Network Graphics (PNG) - 283.76 kB - 05/13/2016 at 14:19 |
For my first try, the output was about 30V! Far more than the attended 12V.
It appears that I am not using a LT1302 but a LT1302-5 for which some R4 and R5 are internally mounted. So, if you are using a LT1302-5 too, remove R4 and use a 570k resistor for R5.
(There is an intern 315k resistor so 315k + 570k ≈
866k.)
