Switched over to using KiPart (from @Dave Vandenbout), and adapted Octavo's OrCAD part: https://github.com/graycatlabs/OSD335x-KiCad/blob/master/OSD3358-kipart.csv
Only took a couple minutes to make the many-unit symbol with KiPart!
A project log for KiCad OSD335x library
KiCad schematic library and footprint for the Octavo Systems OSD3358
Glad it's working for you guys, Alex. Let me know about features that are missing or not working.
Also, be careful of the pin types in the CSV I provided: some of that is pure guesswork since I don't really know the part like you do. The pin numbers and names should be correct since they were cut-and-pasted right from the datasheet into the CSV file.
