To proof that this is indeed a good idea as a midi controller, the first step was to break one open and attach an Arduino to it's inner sensors. Unfortunately I did not took pictures of that process (next time I will), but I was smart enough to make some during soldering.
As you can see I soldered the two wires that are attached to the sensors to a piece of breadboard and an old Arduino Pro Mini I had laying around.
After testing that I could indeed read out the sensors I bought a midi plug and soldered these to the Arduino as well, to be able to test with some control messages for now. This needs to be a simple proof of concept!
That's it for now, I'm off to go program a simple program to send some midi signals! Checkout the git if you are interested! Expect updates somewhere next week when we finished testing.
