So, a punch card reader isn't really going to be that great without some punched cards to read.
However, I don't have any punched cards.
So, off I head to Lasery McLaserface* to make some!
What I actually did was go to http://www.masswerk.at/keypunch/ and typed a message. From there I could download a .png file of a punch card
Potrace should be able to trace the edges of the image and create a dxf - however, it doesn't like .png files and even as a bitmap I couldn't get the output right. So I used Inkscape (which has Potrace built in) to do this bit.
The .dxf looked good, and came out pretty well - although some of the holes had just the tiniest whisker of card holding the chad on. At 97mm x 255mm it is bigger than 83mm x 187 of a standard size card, but at least it gives me something to get started on.
* Lasery McLaserface is the name of the laser cutter at Nottingham Hackspace
Wow that "pipe" is a bit... complex :-D
Why not just understand how bytes are transformed/encoded into punched cards directly ?
Understanding the transformation/encoding isn't the hard bit (Well, I hope not - I have to do the untransforming/unencoding bit later!).
Getting from a set of 1's and 0's on a PC to a punched card shaped dxf file would pose a serious challenge to me though. And if there's already a website that does that bit for me, why invent the wheel? :-)
because the wheel is simpler than the brittle, funky and web-dependent workflow ? :-D
