Examples
A project log for 3D Printed Chamfer Tool
Slide this Japanese style hand plane along any rough corners to give them a clean chamfer (AKA beveled edge). Uses a standard razor blade.
alex-richAlex Rich • 05/20/2016 at 00:29•0 Comments
Some examples of what the tool can do, here is a rough block of black ABS cut to size with a saw:
Here it is after a tiny chamfer was added
examples of larger chamfers you can get by adjusting razor blade depth
