-setup raspberry pi with Jessie
-installed mosquitto on raspberry pi
wget http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
sudo apt-key add mosquitto-repo.gpg.key
rm mosquitto-repo.gpg.key
cd /etc/apt/sources.list.d/
sudo wget http://repo.mosquitto.org/debian/mosquitto-jessie.list
sudo apt-get update
sudo apt-get install mosquitto mosquitto-clients
-setup esp8266 using an FTDI serial USB adapter set to 3.3V:
-Use a 3.3V regulator or a 3.3V supply for the ESP itself, not from USB (it can sink a lot of current)
-Vcc => 3.3V
-EN => Vcc
-GPIO15 => GND
-GPIO2 => Vcc via resistor (I used 10k)
-GPIO0 => GND for flashing, then moved to Vcc for runtime
-Rx => FTDI Tx
-Tx => FTDI Rx
-FTDI GND => GND
-use esptool to flash NodeMCU float (dht,file,gpio,mqtt,net,node,tmr,uart,wifi)
esptool.py --port /dev/ttyUSB0 --baud 57600 write_flash 0x00000 firmware.bin
-move GPIO0 to Vcc
screen /dev/ttyUSB0 9600
wifi.setmode(wifi.STATION) wifi.sta.config("ESSID","password")
print(wifi.sta.getip())
-setup raspberry pi 3 as wifi access point (no NAT):
-adafruit article below
-changed hostname
-isc-dhcp-server
-hostapd (device is nl80211)
sudo apt-get update
sudo apt-get install hostapd isc-dhcp-server
/etc/dhcp/dhcpd.conf:
# Sample configuration file for ISC dhcpd for Debian
# The ddns-updates-style parameter controls whether or not the server will
# attempt to do a DNS update when a lease is confirmed. We default to the
# behavior of the version 2 packages ('none', since DHCP v2 didn't
# have support for DDNS.)
ddns-update-style none;
# option definitions common to all supported networks...
#option domain-name "example.org";
#option domain-name-servers ns1.example.org, ns2.example.org;
default-lease-time 600;
max-lease-time 7200;
# If this DHCP server is the official DHCP server for the local
# network, the authoritative directive should be uncommented.
authoritative;
# Use this to send dhcp log messages to a different log file (you also
# have to hack syslog.conf to complete the redirection).
log-facility local7;
# No service will be given on this subnet, but declaring it helps the
# DHCP server to understand the network topology.
#subnet 10.152.187.0 netmask 255.255.255.0 {
# This is a very basic subnet declaration.
#subnet 10.254.239.0 netmask 255.255.255.224 {
# range 10.254.239.10 10.254.239.20;
# option routers rtr-239-0-1.example.org, rtr-239-0-2.example.org;
# This declaration allows BOOTP clients to get dynamic addresses,
# which we don't really recommend.
#subnet 10.254.239.32 netmask 255.255.255.224 {
# range dynamic-bootp 10.254.239.40 10.254.239.60;
# option broadcast-address 10.254.239.31;
# option routers rtr-239-32-1.example.org;
# A slightly different configuration for an internal subnet.
#subnet 10.5.5.0 netmask 255.255.255.224 {
# range 10.5.5.26 10.5.5.30;
# option domain-name-servers ns1.internal.example.org;
# option domain-name "internal.example.org";
# option routers 10.5.5.1;
# option broadcast-address 10.5.5.31;
# default-lease-time 600;
# max-lease-time 7200;
# Hosts which require special configuration options can be listed in
# host statements. If no address is specified, the address will be
# allocated dynamically (if possible), but the host-specific information
# will still come from the host declaration.
#host passacaglia {
# hardware ethernet 0:0:c0:5d:bd:95;
# filename "vmunix.passacaglia";
# server-name "toccata.fugue.com";
# Fixed IP addresses can also be specified for hosts. These addresses
# should not also be listed as being available for dynamic assignment.
# Hosts for which fixed IP addresses have been specified can boot using
# BOOTP or DHCP. Hosts for which no fixed address is specified can only
# be booted with DHCP, unless there is an address range on the subnet
# to which a BOOTP client is connected which has the dynamic-bootp flag
# set.
#host fantasia {
# hardware ethernet 08:00:07:26:c0:a5;
# fixed-address fantasia.fugue.com;
# You can declare a class of clients and then do address allocation
# based on that. The example below shows a case where all clients
# in a certain class get addresses on the 10.17.224/24 subnet, and all
# other clients get addresses on the 10.0.29/24 subnet.
#class "foo" {
# match if substring (option vendor-class-identifier, 0, 4) = "SUNW";
#shared-network 224-29 {
# subnet 10.17.224.0 netmask 255.255.255.0 {
# option routers rtr-224.example.org;
# subnet 10.0.29.0 netmask 255.255.255.0 {
# option routers rtr-29.example.org;
# pool {
# allow members of "foo";
# range 10.17.224.10 10.17.224.250;
# pool {
# deny members of "foo";
# range 10.0.29.10 10.0.29.230;
subnet 192.168.42.0 netmask 255.255.255.0 {
range 192.168.42.10 192.168.42.210;
option broadcast-address 192.168.42.255;
option routers 192.168.42.1;
option domain-name "local";
option domain-name-servers 8.8.8.8, 8.8.4.4;
/etc/default/isc-dhcp-server
# Defaults for isc-dhcp-server initscript
# sourced by /etc/init.d/isc-dhcp-server
# installed at /etc/default/isc-dhcp-server by the maintainer scripts
# This is a POSIX shell fragment
# Path to dhcpd's config file (default: /etc/dhcp/dhcpd.conf).
#DHCPD_CONF=/etc/dhcp/dhcpd.conf
# Path to dhcpd's PID file (default: /var/run/dhcpd.pid).
#DHCPD_PID=/var/run/dhcpd.pid
# Additional options to start dhcpd with.
# Don't use options -cf or -pf here; use DHCPD_CONF/ DHCPD_PID instead
#OPTIONS=""
# On what interfaces should the DHCP server (dhcpd) serve DHCP requests?
# Separate multiple interfaces with spaces, e.g. "eth0 eth1".
INTERFACES="wlan0"
/etc/network/interfaces:
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet static
# wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
address 192.168.42.1
allow-hotplug wlan1
iface wlan1 inet manual
/etc/hostapd/hostapd.conf:
interface=wlan0
driver=nl80211
ssid=mbed
hw_mode=g
channel=6
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=<pass>
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
/etc/default/hostapd:
# Defaults for hostapd initscript
# See /usr/share/doc/hostapd/README.Debian for information about alternative
# methods of managing hostapd.
# Uncomment and set DAEMON_CONF to the absolute path of a hostapd configuration
# file and hostapd will be started during system boot. An example configuration
# file can be found at /usr/share/doc/hostapd/examples/hostapd.conf.gz
DAEMON_CONF="/etc/hostapd/hostapd.conf"
# Additional daemon options to be appended to hostapd command:-
# -d show more debug messages (-dd for even more)
# -K include key data in debug messages
# -t include timestamps in some debug messages
# Note that -B (daemon mode) and -P (pidfile) options are automatically
# configured by the init.d script and must not be added to DAEMON_OPTS.
#DAEMON_OPTS=""
links:
http://hackaday.com/2016/05/09/minimal-mqtt-building-a-broker/
http://hackaday.com/2016/05/17/minimal-mqtt-networked-nodes/
https://github.com/themadinventor/esptool
https://github.com/esp8266/esp8266-wiki/wiki/Boot-Process#esp-boot-modes
https://learn.adafruit.com/setting-up-a-raspberry-pi-as-a-wifi-access-point/install-software
additional reference: https://frillip.com/using-your-raspberry-pi-3-as-a-wifi-access-point-with-hostapd/
next time: http://blog.falafel.com/working-with-files-in-nodemcu-on-the-esp8266/
