Some five years ago I bought a nice UART-over-Bluetooth adapter module. The module emulates a serial port (UART) over a Bluetooth connection. All necessary chips and an antenna are mounted on a small PCB board depicted below.
The type I’ve got is the cB-OEMSPA310i-04 with an internal antenna. The module requires only a 3.3V power.
