My Knog Blinder 4 bike lights (which I love) have a weak point in the silicon strap right near the metal tensioner. Both of them broke there, so I modelled up a frame to replace the silicon with some outdoor climbing 3mm static cord that's 70c a metre.
The friction against the holes in the 3D model is enough to hold the climbing static cord when it's under tension, which means it can be easily adjustable for different sized handlebars and seat posts.
This solution works on both front and rear Knog Blinders.
Details
I've put the project up on GitHub too, so if you'd like to remix it or make any changes, fork it and or submit an issue/pull request!
Files
knog-fix.FCStd
Here's the FreeCAD design file. Feel free to remix or edit it to make it better.
