Before I was able to do a PCB design I was making this project using a low quality single sided perfboard and for jumper wires I peel an unused LAN cable.
Fortunately I have an Arduino Micro from adafruit that has been sitting in a box for several years and it is a great to use it.
For powering the Device I use two CR2032 coin cell battery in series to give the board enough power which later I learned that it is not the best for this project because it only run for 20-30 minutes.
After Hours of soldering this what I come up with
It was a succes attempt but the run time wasn't enough
Hendra Kusumah
