Concept
The basic idea is to use a cheap 3-axis magnetometer (aka compass) sensor to sample the magnetic field vector, B, at a number of 3D positions within a volume, then use interpolation to estimate the field in between these positions. An off-the-shelf 3D printer is used to scan the sensor through the volume. The scanning program uses vanilla g-code commands suitable for any industry-standard printer. Compensation for external fields, such as those produced by our planet or stepper motors within the printer can be made one of two ways. For permanent magnets, an initial baseline scan can be made without the target, then the results subtracted from the actual scan. In the case of electromagnetic targets, taking two data points at each position - one with the current on, and one off - achieves the same goal. A number of different visualizations can then provide an interactive exploration of the field. Using python for the scanning app and WebGL for the visualization should provide a relatively platform-independent experience.
The first rough prototype used off-the-shelf modules, including an Arduino and an HMC5883L breakout board from Adafruit to get a proof-of-concept result. I've now switched to using a Melexis MLX90393 magnetometer, which allows a much wider (60x more) range of field strength, and am designing a custom scanning head using this part.
Show Me Something
Here's a sneak-peek from the proof-of-concept (with a hard-coded/pre-computed visualization of actual data). More details on this first test can be found in the first project log. The viewer is a WebGL app hosted on my server, since I can't embed it here:
MagView @ Zed Naught Labs
This may or may not work on your platform: at least WebGL is required. I've tested it on linux (Firefox, Chromium), my Android phone, and a friend's iPad and Windows 7 machine, and it worked on all of those. It bugs me that this has to be off-site: I'm offering a one-skull bounty to anyone who can get embedded WebGL to work directly in hackaday.io :-)
Project Phases
I've divided planned development into four basic phases, intended as rough guidelines on which to base releases:
Phase 0
The proof-of-concept that generated the results above. This code is truly hacked together, and a release would cause more problems than it solved, so it's not going out. More details of this effort can be found in the first project log.
Phase 1
First planned release. The goal is to have two programs, a python scanner and a WebGL browser-based visualizer. Features to possibly include:
Scanning
Visualizations
Sensor
Phase 2
Scanning
Visualizations
Sensor
Phase 3
This phase is the full-custom hardware step, incorporating everything learned in the first [three]. As such, it's subject to radical change as we go.
Scanning
Visualizations
Sensor
For the Nerds
There are several issues this project doesn't currently address. I discuss a few that I'm aware of here; readers will undoubtedly find more. Please add to the discussion as you find them - maybe we can improve the project going forward.
First, linear interpolation of the vector magnetic field, B, will obviously introduce errors - apart from the usual error we might obtain through interpolation, we know (from Gauss and subsequently Maxwell) that the field should obey:
that is, the field is divergence free (solenoidal). Even if our sampled values are from a divergence-free field, linear interpolation produces a result which may have non-zero divergence. For our purposes, I'm going to ignore this. Just don't get too excited if you "discover" magnetic monopoles in your data.
Second, the magnetic field we measure is affected by any magnetic materials near the sensor. In my case, the printer I used for the quick prototype, a Solidoodle 3, is built into a steel cube frame which undoubtedly distorts the measured field somewhat. Although the two calibration methods proposed above can mitigate the effects of external fields (such as that of the Earth or printer stepper motors), the distortion of the measured fields by local magnetic materials remains uncorrected. Maybe you can think of a way to fix this.
I just found the #low-field MRI project; @peter jansen is also scanning fields as part of a more ambitious effort. It seems he has put some serious thought into keeping magnetic materials away from the sensor; I'll have to study that a bit.
