urrent sensor provides an analog output of 0-5v; it can measure both positive and negative current. Therefore, when there is no load, sensor outputs 2.5v.
Before I start to build the electronics and the enclosure, I have to check the sensitivity of the current sensor.
Arduino has 5v ADC but ESP8266 works with 3.3v. I could build a simple voltage divider to lower the sensor output voltage but instead of that I connected sensor output in reverse polarity. Because servo always draw positive current, sensor output will never reach 2.5v. So when the servo is drawing current, I read a lower voltage from the ADC.
I wrote a simple sketch to output analog value using Web Socket connection. With an help of small JavaScript library, I managed to output analog value as graph.
Actually sensor is pretty accurate but there was too much noise on the analog input. It's impossible to determine a threshold point without using a smoothing algorithm.
const int numReadings = 10; int readings[numReadings]; int readIndex = 0; int total = 0; int inputPin = A0; int smoothValue() { total = total - readings[readIndex]; readings[readIndex] = analogRead(inputPin); total = total + readings[readIndex]; readIndex = readIndex + 1; if (readIndex >= numReadings) { readIndex = 0; } return total / numReadings; }
You can find rest of the code at my GitHub repository.
