Wireless Programming
A project log for Home automation on the cheap
Using an esp8266, arduino nano, a salvaged usb power supply, and a couple relays you can automate anything
thjubeckthjubeck 09/19/2016 at 05:150 Comments
For wireless programming/re-programming, I connect to the esp using hardware virtual serial port found here.
Be sure to disable NVT in the settings or you will not be able to program the controller.
Rich text editor
