- Drilling into Stainless, although it weighs more and is heavier than "Butter" aluminum, is a pain in the A$%.
- I have been making mistake after mistake since I lack a drill press.
- So, with these mistakes showing up, I have to consider the damage and reconfigure.
- I have all the equipment so far.
- All equipment is ready to be assembled except for the drilling of the stainless steel that will house my two motors and weed-eater engine for propelling the blade to cut.
- Once the stainless is drilled, I can add my other electric DC motor to create a triangle of wheels. Two motors will carry sprockets as wheels for grass interference and there will be one swivel wheel in the front to create extra support.
- So...in the meantime is when I can alter this software to suit my needs. I may need assistance in the software field but I will let people know soon.
- If you get bored and you are reading this info, please try to contact me with any questions or concerns.
Seth
