bossac successfully hacked.
blinky.c successfully loaded.
LED is blinking!
A project log for se7eduino
small atmel SAM S70 (300MHz cortex-M7) based dev board. similar to the arduino due, except super-mega-turbocharged.
LED is blinking!
I am trying to get the SAMS70N21B to program over SWD using segger J-link with no luck so far. I haven't tried BOSSAC yet. Did you try SWD at all? Would you recommend BOSSAC instead?
hooray!
