Posted a log a while ago on an assembly screwup, where some soldered parts kept the Arduino shield from fitting properly in the Arduino. Now that the instructions are working again, have modified steps 4 and 7 to incorporate the fix.
A project log for Affordable Reflectance Transformation Imaging Dome
A simple and inexpensive way to image and analyze subtle surface details on objects.
