Threw together a quick script for testing functionality
#! /usr/bin/env python3
This converts keyboard input to basic OSC commands for controlling video playback
import argparse
import sys
import tty
import termios
from pythonosc import osc_message_builder
from pythonosc import udp_client
def getch():
fd = sys.stdin.fileno()
old_settings = termios.tcgetattr(fd)
try:
tty.setraw(fd)
ch = sys.stdin.read(1)
finally:
termios.tcsetattr(fd, termios.TCSADRAIN, old_settings)
return ch
if __name__ == "__main__":
parser = argparse.ArgumentParser()
parser.add_argument("--ip", default="127.0.0.1",
help="The ip of the OSC server")
parser.add_argument("--port", type=int, default=12345,
help="The port the OSC server is listening on")
args = parser.parse_args()
client = udp_client.UDPClient(args.ip, args.port)
keymap = {
'p' : "/play",
'n' : "/next",
'b' : "/previous",
'f' : "/faster",
's' : "/slower"
ch = ''
while ch != 'q':
ch = getch()
if ch in keymap:
msg = osc_message_builder.OscMessageBuilder(address = "/video"+keymap[ch])
msg = msg.build()
client.send(msg)
