This is the sequence I think I will follow during this summer to build a complete Aloise turbine:
- definition of the key points of the project: done
- evaluation of turbine dimensions in order to serve Aloise needs: on going
- selection of the best vertical wind turbine considering the African context: on going
- wind tunnel tests: Savonius and Darrieus type turbines: to do
- simulation with a great open-source software, Q-Blade and data validation: to do
- selection of the best fitting PMG generator, between bicycle hub dynamos and scooter alternator: on going
- building an MPPT simple charger, Arduino based: to do
- completion of 3G anemometer with Particle/Hologram SIM in order to send wind data directly on a server: to do
- completion of a local SD memory wind datalogger: on going (done...!)
- prototype building: to do
- prototype testing: to do
Obviously I can't do this all alone. Mirko will help me, as usual, and a couple of colleagues will be involved during the summer.
And ok, in field tests will be done as always we did before... ;-) have a look to the videos!
