It's still not ready, nor properly documented - but finally the entire StageGhost kit's code is at GITHub:
https://github.com/diemastermonkey/stageghost
I remind you that StageGhost is the bot behind this project, for which DronesoundTV is really a proving grounds.
The Wiki there also has minimal instructions for the bravest-at-heart, but the entire setup still needs complete testing.
You'll also find much cruft, including programs you might not need for your installation. These will be much easier to remove, soon.
PS: I'm considering branching-off a separate project here for StageGhost the bot, so as to focus this project on the art side of DronesoundTV.
Oh also, the channel now has its own URL! See you at http://youtube.com/dronesoundtv
