Just a tiny reminder that Siemens MCU guys were probably located in Germany, back in the 90's. In case control logik is not enough for you, there you have schadow latch.
Source: SAB805x7 datasheet: http://www.keil.com/dd/docs/datashts/infineon/80c5x7_um.pdf
jaromir.sukuba
Wie schade... ow...
