And here it is in action
When triggered, It beeps a few times and the LED's will show you, that there was an activation. You have to reset the led manually.
The quick build:
fist a 3D design in Sketchup 8
Lasercut parts
All together
Little update:
Had to add an external antenna to increase the range. Being a designer is really not my mojo :)
