There are two options for gathering measured data from remote locations: data loggers and sensor networks. Below, I listed my impressions on some of the solutions and their pros and cons. Some of the impressions outlined lead to the decision to start a new wireless sensor framework, and some of the impressions were gathered during the development.
- Academic WSN (e.g., Mica, Telos, Wispes)
- + Mesh networking
- + Battery powered
- + Tested
- – Seem to be outdated / not active
- – Not really open source
- – Small community
- – Seem to be complicated
- Meant for electrical engineers
- Meant for research on wireless networks and not on the measured data
- – Rather expensive
- Commercial WSN (e.g., Libelium, Advanticsys)
- + Battery powered
- + Mesh networking
- + Flexibility regarding internet access (Libelium)
- + Flexibility regarding sensor choice (Libelium)
- + Lots of documentation (Libelium)
- + Tested
- – Expensive
- Commercial data loggers (e.g., Testo, Hobo)
- + Battery operation
- + Tested
- – They are data loggers: You only know after the measurement, whether it was successful or not.
- – Limited selection of sensors from one supplier. You may need products from multiple suppliers
- – Expensive despite limited functionality
- Not open source
- Academic data loggers (e.g. OSBSS, Cave Pearl)
- + Arduino based
- + Tutorials available
- + Battery powered
- – Still in prototyping stage
- – Not modular
- – They are data logger (see above)
- Arduino + Shields / Proto-boards (e.g., Arduino, Moteino)
- + Huge community
- + Open source
- + Modular sensor arrangement is possible
- – Not clear if battery operation is possible
- – Time for Manufacturing
- – Still rather expensive
- – Larger form factor
- – Not tested
- Custom Arduino based solution
- + Potentially cheaper
- + Huge community, since it is based on the Arduino ecosystem
- + Potentially fast(er) to manufacture (if SMD parts are used)
- + Potentially small (enough) form factor
- + Virtually infinite flexibility (if modular)
- – Risks: reliability, manufacturing
Despite the plethora of papers on WSNs, I could not find a framework that is truly open source and simple enough that I would dare to tinker with it. This led me to think that there is a niche for a simple and modular framework for remote measurements. Although our research field is buildings, I could imagine that it could be used in other fields.
I would like to mention two academic data logger projects, which inspired me to publish our work on GitHub and on hackaday.io:
- The Cave Pearl Project (https://hackaday.io/project/6961-the-cave-pearl-project)
- OSBSS: Open Source Building Science Sensors (http://www.osbss.com/)
Both provide source files, build instructions and tutorials. Check them out!
If there is a modular open-source framework for remote measurements that I am not aware of, let me know in the comments.
