The Big One is a flying model rocket version of the rocket seen in the movie Toy Story. The Fins and mounting are printed as one piece as is the nose cone. The parts are designed for a Quest Aerospace 50mm tube (cardboard), that can be purchased from them directly. The engine mounting setup is also going to printed with the exception of a cardboard tube for holding the engine, the mount will be printed out of heat tolerant plastic.
Specs:
- 3D Printed Nose Cone
- 3D Printed Fin Body w/ Launch lug
- 50mm Quest Aerospace Body Tube
- 25mm Quest Aerospace Engine Tube
- 3D Printed Engine Mounting System
- C/D/E Engine Sizes
- Quest Aerospace Paraschute
AVR
