What is a development board without sensors to play with?
As i already stated i hate connecting stuff using a breadboard and jumper wires. While this allows a great extensibility, it is always the one thing that pushes me away from experimenting.
So i am going to reorder the Extension ports in a way that a wide variety of sensors can be directly plugged in. For the ones that cannot - i will add one adapter board to host them as well.
I have not yet finalized the set of natively supported sensors, but ones that are definitely going to be in are:
- Light / Lux
- Humidity
- Pressure
- UV Light
- Guesture
- RFID Scanner
Some different types of displays can be supported as well:
- 0.96" OLED
- 2.4" TFT
- 20x2 or 20x4 Character Display
And of course some actuators
- Relay
- Servo
As part of the crowdfunding campaign there will be different sets of those sensors. Also for some of them i plan to include native support in the Firmware so that you can start using them in no time!
Vladimir Savchenko
