Current Status and Testing
A project log for TrillSat
Texting Without Cell Towers, Power Grid, or the Internet: IoT meets AX.25 Aboard an Arboreal Space Elevator
lee-djavaherianLee Djavaherian 04/07/2018 at 06:400 Comments
Current Status
I've spent about one year programming the core systems, and one year building, and it is now in the final stages of writing/perfecting the highest level algorithms and adjusting for real-world use.  The packet radio interface has been tested on-the-air and does work.  The PBBS system and APRS beacon has been tested in simulation (and works), but hasn't yet been tested over-the-air.  The TROT drive system has been tested on the indoor test frame, not in use outside on actual trees or weather conditions yet, but much of it is still under manual control.  The full size 2m/70cm antenna is only theoretical at this point but is simple to build, something I have left to the very end, but I will need to add an appropriate female SMA bulkhead adapter to extend the 50 ohm terminal outside the Radio Box.  The THUMP system is only about 50% completed, as the SIMTHEO algorithm does work, but inverting it and adapting it to the tethered accelerometer interrupt is mainly theoretical at the time of this writing.
All electromechanical systems are functioning, and I have created a large set of XMPP commands to manually control the craft and read its sensors, but there are only a few autonomous robotics systems in place at the time of this writing.
Working autonomous robotic systems
Autonomous robotic systems that still need to be implemented
Results of testing so far:
Negative
Positive
Rich text editor
