# Watch out barbecue fans - the summer is comming #
How it should work?:
Attach a simple clamp at barbecue, mount a 80x80mm PC fan and power it up, thus unleash the hell.
Why it is a must have?:
A simple hand-powered fan it not new. It will consume your muscle power to get the fire up. This "Grillfan" should have a (9-12V) battery, a temperature sensor and a transistor to shut up the fan if the coal is hot enough (for this a poti, is desireable).
How it looks like?:
A prototype is just in planning. If I have the first images, I will post it here - to my barbecue fans :)
Details
Problems to solve:
- Heat isolation - should be small, well isolated and small to fit into every backpack
- Good grip on each barbecue set - mangetic, mechanic, ?
Components
1×
Mounting clamp
1×
9V Battery / 12V Battery
depends on the power consumption of the PC fan
