There are countless code examples for debouncing a switch solely with software, but there's really no reason to use an example, it only takes a few lines of C to do this, even for a relative beginner like me. Here's what I came up with:
void ISR_Debounce ( uintptr_t context, uint32_t alarmCount )
if((BSP_SwitchStateGet(BSP_SWITCH_1) == BSP_SWITCH_STATE_PRESSED) && debounceData.sw1counter < 5)
debounceData.sw1counter++;
if(BSP_SwitchStateGet(BSP_SWITCH_1) == BSP_SWITCH_STATE_RELEASED) debounceData.sw1counter = 0;
if((BSP_SwitchStateGet(BSP_SWITCH_2) == BSP_SWITCH_STATE_PRESSED) && debounceData.sw2counter < 5)
debounceData.sw2counter++;
if(BSP_SwitchStateGet(BSP_SWITCH_2) == BSP_SWITCH_STATE_RELEASED) debounceData.sw2counter = 0;
appData.dbSwitch1 = (debounceData.sw1counter == 5) ? 1 : 0; //Ternary for setting debounce output.
appData.dbSwitch2 = (debounceData.sw2counter == 5) ? 1 : 0;
sw1counter and sw2counter are defined in my debounceData structure as uint8's, and dbSwitch1 and dbSwitch2 in the appData struct are bools.
The function parameters (uintptr_t context and uint32_t alarmCount) are there because the callback parameter in the dynamic timer driver is defined like this:
typedef void (* DRV_TMR_CALLBACK)(uintptr_t context, uint32_t alarmCount);So you give it what it wants, right? :) I did a little copying from Microchip's typo-ridden Harmony examples.
Here's the business:
- Every X number of timer ticks (as defined when you register the timer alarm) the debounce ISR function runs.
- A switch is first checked if it's pressed and the counter variable is less than 5. If both of these conditions are met, the counter is incremented.
- If the switch is in its released state, the counter is reset back to 0.
- A ternary operation is used to set the debounced output. If the counter is 5, the output is true.
This just implements a really simple kind of low-pass button-press filtering. In Verilog, I've seen the same technique used, but with a several-bit-wide shift register. All the bits in the register are ANDed together, so when the register fills with 1's from a button press, the output of the AND gate is your debounced button bit.
