I'm generally dehydrated so I'm making a water intake tracker using a scale and NFC chips stuck to my vessels.
Initially I was going to skip this bit in the docs but writing these logs inspired me to do this thoroughly. So I went and code reviewed most of the libraries for the HX711 on github.
Read more »So I built this hardware ages ago but it was up to the software to do the heavy lifting. I finally decided to pick this up again after finally getting around to figuring out the software platform I was going to use for my projects (updates for my other project coming soon). I decided Node-Red was the most appropriate as the data flow paradigm is well suited for sensor based data feeds.
But this is about the hardware so read on.
