I'll continue to put up interesting things as I think of them. Here are a few interesting tidbits.
Most often used post tags:
misc hacks | 2327 |
Arduino Hacks | 1792 |
news | 1492 |
classic hacks | 1291 |
robots hacks | 1248 |
tool hacks | 1200 |
home hacks | 1024 |
led hacks | 1024 |
Microcontrollers | 893 |
Hackaday Columns | 813 |
peripherals hacks | 778 |
Featured | 750 |
transportation hacks | 742 |
slider | 711 |
3d Printer hacks | 696 |
hardware | 661 |
security hacks | 657 |
Raspberry Pi | 634 |
digital cameras hacks | 589 |
home entertainment hacks | 587 |
Perhaps unsurprisingly, arduino hacks are near the top of the list.
If you look at the most prolific authors you get:
Mike Szczys | 5716 |
Brian Benchoff | 3834 |
Caleb Kraft | 1567 |
Eliot | 1332 |
James Hobson | 1063 |
Mike Nathan | 1039 |
Will O'Brien | 805 |
Adam Fabio | 530 |
Elliot Williams | 405 |
Al Williams | 401 |
Kristina Panos | 322 |
Rich Bremer | 290 |
Jakob Griffith | 269 |
Eric Evenchick | 265 |
Rick Osgood | 225 |
Gerrit Coetzee | 215 |
Marsh | 213 |
Jeremy Cook | 199 |
Dan Maloney | 198 |
Bryan Cockfield | 187 |
Kevin Dady | 187 |
Mathieu Stephan | 180 |
Anool Mahidharia | 160 |
Juan Aguilar | 160 |
Vine Veneziani | 137 |
Plotting the number of articles per week, segregated by the top ten authors, over time gives the following picture:
You can clearly see where submitters became active and when when they stopped. Brian had a early submission somewhere in 2006 before he joined HAD. Mike Szczys was active early and then starting tailing off around 2013-- other behind the scenes activities I imagine.
