I'll continue to put up interesting things as I think of them. Here are a few interesting tidbits.
Most often used post tags:
| misc hacks | 2327 |
| Arduino Hacks | 1792 |
| news | 1492 |
| classic hacks | 1291 |
| robots hacks | 1248 |
| tool hacks | 1200 |
| home hacks | 1024 |
| led hacks | 1024 |
| Microcontrollers | 893 |
| Hackaday Columns | 813 |
| peripherals hacks | 778 |
| Featured | 750 |
| transportation hacks | 742 |
| slider | 711 |
| 3d Printer hacks | 696 |
| hardware | 661 |
| security hacks | 657 |
| Raspberry Pi | 634 |
| digital cameras hacks | 589 |
| home entertainment hacks | 587 |
Perhaps unsurprisingly, arduino hacks are near the top of the list.
If you look at the most prolific authors you get:
| Mike Szczys | 5716 |
| Brian Benchoff | 3834 |
| Caleb Kraft | 1567 |
| Eliot | 1332 |
| James Hobson | 1063 |
| Mike Nathan | 1039 |
| Will O'Brien | 805 |
| Adam Fabio | 530 |
| Elliot Williams | 405 |
| Al Williams | 401 |
| Kristina Panos | 322 |
| Rich Bremer | 290 |
| Jakob Griffith | 269 |
| Eric Evenchick | 265 |
| Rick Osgood | 225 |
| Gerrit Coetzee | 215 |
| Marsh | 213 |
| Jeremy Cook | 199 |
| Dan Maloney | 198 |
| Bryan Cockfield | 187 |
| Kevin Dady | 187 |
| Mathieu Stephan | 180 |
| Anool Mahidharia | 160 |
| Juan Aguilar | 160 |
| Vine Veneziani | 137 |
Plotting the number of articles per week, segregated by the top ten authors, over time gives the following picture:
You can clearly see where submitters became active and when when they stopped. Brian had a early submission somewhere in 2006 before he joined HAD. Mike Szczys was active early and then starting tailing off around 2013-- other behind the scenes activities I imagine.
pjkim00
