What is a Sun Tracker?
A sun tracker is a automatic platform for solar panel which always turns its face towards the sun throughout the day like a sun flower by using some photo sensors like Photoresistors.
the step by step process is giving in the pdf file and in the link below
vishnubhatlaniranjan
anh pham
Cyber Jannah Sakura
NeoTheFox
Or... You can replace the pot in the servo with 2 cds cells, send a centering signal to the servo, and put a piece of cardboard between the cds cells. When they are unevenly illuminated the servo will run one way or the other (cw/ccw). Just remember to hack out the servo stops inside the case. Using an Arduino for this is like killing a mosquito with a shotgun. Effective, but not efficient. Have fun.
