And again optic. I found this website to calculate the object distance.
http://hyperphysics.phy-astr.gsu.edu/hbase/geoopt/image4.html
The best optics for this project are lenses with a focal length between 100mm and 120mm.
The Maginifiging effect will be between 2.9x and 3.5x, witch gave the best results and the distance between the lens and the display will be something between 70mm and 80mm.
