It took me a few days to analyse the Data coming from my Bluetooth Multimeter Owon B35T.
After I understood most of the values, I wrote a little program to transfer the Data directly to my Arduino Glass. Amazing, connecting to measuring points, and seeing the Data directly in front of where you are working.
como pasabas la informacion al monitor serial
Hi Alain, could you help me, how to connect the BT35 manualy whit the serial program?
I think this is great, I have a uno setup with 1.8tft screen how do I connect it manually,could you please advise I can see bluedat string but it's not used.
Excellent! Can you share this program, please?
Hi, the soft is not completed, but I uploaded the one I use for the moment for my tests, on my github
https://github.com/awall9999/Arduino-Glass/tree/master/oledbluetest2
It's working, but you have to connect the BT35 manualy with the serial programm. I hope I will have a ready to use version in a few days.
